No start motor after engine harness swap. :(
Old Jun 17, 2007 | 04:25 PM
PoorMan's Avatar
I swapped the engine harness out of my A4 with an M6 harness. I am in the middle of a T56 swap btw. Same year harness. Anyway, I have the clutch switch tie wrapped and confirmed I am getting 0 ohms on that switch.
I don't hear my solenoid "clicking" when I try to crank it. With the ignition "on" I am getting voltage at the starter motor. Any ideas???
The trans is not in the car, Only the flywheel. Trying to check for an oil leak before I install the trans.
JD
Old Jun 17, 2007 | 04:49 PM
1racerdude's Avatar
Use a jumper or remote starter switch on the two poles on the solenoid and see . If it engages with the jumper then ya got the wrong "LITTLE' wire connected to the solenoid.
Old Jun 17, 2007 | 04:54 PM
PoorMan's Avatar
Thank you for the post. I will try that.
Old Jun 18, 2007 | 07:23 PM
PoorMan's Avatar
Thanks. That was it.
Old Jun 19, 2007 | 11:33 AM
1racerdude's Avatar
Anytime
willismoons
Feb 14, 2015 08:42 PM
Jan 5, 2015 07:14 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
centric
Aug 15, 2002 09:04 PM
