no spark lt1
Old Oct 12, 2004 | 07:03 PM
karl81talt1's Avatar
Angry no spark lt1
hey guys im new here so ill start with a little history.
i have an 81 turbo trans am with a lt1 and a six speed from a 95 camaro.
my problem is i have no spark even after i checked all my wiring (its a freeking mess since im using the factory harness) it all checked out. i have power everywhere i should. its killing me the only dtc's i have are about the coolant temp and fans. i also replaced the module and distibutor with brand new peices with no help. any insite will help. i cant wait to here this thing through my spintech exhaust.
Old Oct 14, 2004 | 04:35 PM
Re: no spark lt1
ttt
Old Oct 14, 2004 | 04:44 PM
Pasky's Avatar
Re: no spark lt1
Is there no spark coming from the coil? Or isthere no spark going to the plugs? If you have spark come from the coil, coil is good, if not, its the coil. If you have no spark going to the wires and you got it from the coil, optispark is bad.
Old Oct 14, 2004 | 05:07 PM
Re: no spark lt1
no spark at coil. but the injectors are firing. its a brand new acdelco opti and icm. I checked the coil with my voltmeter and checked out to be ok. my shop manual says i should have between 1 and 5 volts ac at the icm while cranking. I do not have that. but i do not know why. I think its the pcm but i want to make sure. thanks for the advice
Old Oct 14, 2004 | 07:37 PM
Pasky's Avatar
Re: no spark lt1
I have heard of coils giving the correct voltage and still not working worth a crap. Double check to see if the ICM is installed properly. Im not sure on the fourth gens but is there a fusable link for the coil? Fuse? Check the spark plug wire. Make sure the connector is on good and tight. Only thing I can think of bud.
Old Oct 15, 2004 | 03:32 PM
Re: no spark lt1
Thanks but i wish it was the fuse. i still have 12 volts at the coil whith the key on. and i tried another coil that i know is good.
Old Oct 15, 2004 | 03:39 PM
turbo_Z's Avatar
Re: no spark lt1
You dont have an MSD box hooked up to the ignition, right?
Old Oct 15, 2004 | 03:41 PM
turbo_Z's Avatar
Re: no spark lt1
Id also try another ICM. Just because its new doesnt necessarily mean it works.
Old Oct 16, 2004 | 03:58 PM
Re: no spark lt1
no msd i have the box from the old setup but wanted to get i running before i messed with that. I will try to get another icm to try. I'm looking for another pcm as well but no junkyards around here have any.
Old Oct 16, 2004 | 08:13 PM
curtSr's Avatar
Re: no spark lt1
I had a similar problem when I swapped a 95 lt1 into my tr7 using a factory harness. Some battery leads (12v +) that come off of the fuse block are live with the key on but shut off during cranking. Make sure that you are connected to a feed that does not get killed at start up. That might be your problem.
Curt Sr
Old Oct 18, 2004 | 07:20 PM
Smile Re: no spark lt1
Thanks curt ried that yesterday before i read your reply. but u were dead on thats exactly what it was. It fired up and i shut it off to hook everything up the correct way and then i ahad an injector stick open and it hydrolocked. i posted that in a new thread, i hope it didnt bend anything. Wont know until i get new injectors later this week and fire it up. Hope it doesnt knock. Wish me luck.
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
