No Spark Diagnosis?
Old Oct 26, 2005 | 06:56 PM
slayer6x6's Avatar
No Spark Diagnosis?
We are working on my buddys 94 T/A and have just replaced the opti, coil, and ignition module. After all of this we are still not getting a spark out of the coil.
We did some testing at the ign module connector and found 12V on both pins A and D. We found about 2V AC on pin B and about .2Ohm to ground on pin C. So it looks like we are getting everything we need at the ignition module.
Since we have a good AC voltage at the module, that would tell me that the opti/pcm circuit is working as it should, correct? Im kind of leaning toward a defective module/coil. Am I forgeting anything? Any other tests I can do?
Any inputs or suggestions are very helpful
Old Oct 28, 2005 | 08:00 AM
slayer6x6's Avatar
Re: No Spark Diagnosis?
anyone?
Old Oct 29, 2005 | 03:07 AM
ChevyTuffD.A.'s Avatar
As far as tests go I dont know of any more. The coil and ECM go bad fairly often and could be your problem. Also, check to make sure the connector for the opti wiring harness is working properly, check to make sure all the pins inside are where they should be and not pushed back into the connector itself.
Old Oct 29, 2005 | 03:51 AM
jbird's Avatar
Is there spark at the coil?
Old Oct 29, 2005 | 07:30 AM
slayer6x6's Avatar
Well it turns out that we had a faulty new ign module. We took it back and got another one and she purrs like a kitten now.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
