no screen maf sensor
Hey guys I was cleaning out the camaro n found a box which has the two ends that hold the maf sensor together but no screen,the invoice has the previous owners name on it,i believe he was gonna use it for performance wise.
I researched about no screen maf sensor,I'm getting different results of ppls opinion,but wanted to see what u guys think. Thanks guys.
94 Chevy lt1 camaro z28 pretty much all mods that are common and bolt ons,bigger cam, all suspention etc.
Re: no screen maf sensor
You don't need new ends on a 94 to delete the screen. The screen is held in by a snap ring and is removable.
Leave it in there, for the reasons explained above.
Hey guys one thing I noticed that the coupling between the end of the maf sensor n my kn air filter the coupling that's inserted the maf sensor it's not the correct size I can't insert it all the way in,i looked at it bcuz in the 3rd gear my camaro is like jerking n hesitating,I'm not hearing misfire or popping.
but I just need to make sure it's called a coupling to hold the maf n end of the kn air filter
https://www.google.com/search?q=lt1+coupling+for+maf+sensor&prmd=sivn&sou rce=lnms&tbm=isch&sa=X&ved=0ahUKEwj2l-HaqYDWAhUMyWMKHXZwD0sQ_AUICygC&biw=320&bih=486#img rc=mgnKVponwrcJzM:
Here's a pic of what i need
Is the K&N a recent purchase? If so, is appears they are including a filler piece for the non-MAF 1993 cars, and making it a 1993-1997 kit. The filler piece on the end is not used on 1994-97 cars.
If that is not the problem you are having, try explaining it again, because what you wrote in post #5 is unclear.
Nothing inserts into the MAF sensor. The MAF sensor fits inside the coupling. Do you possibly mean that the rubber coupler that connects to rigid plastic K&N air duct to the MAF sensor does not allow the MAF sensor to be inserted?
If so, what is the outside diameter of the MAF senor end? What is the inside diameter of the short rubber coupling?
....the coupling that's inserted the maf sensor it's not the correct size I can't insert it all the way in,
OP
a picture of "your" MAF/intake connection issue will be helpful for any of us to better understand WTF your issue is..
Nothing goes "inside" the MAF...it should clamp on the outside, both ends
If what you need is a coupling between the MAF and K&N, go to your home supply store and get a Fernco rubber sewer pipe coupling of the correct size. Warm it in some hot water to make it pliable.
[QUOTE=shoebox;6994589]Your link shows hundreds of different things.[/QUOTE
hey Rob sorry,and Fred too,i fixed the couple I cut it down to get the maf sensor inside so that it doesn't keep slipping out,no it wasn't a recent purchase I believe the previous owner ordered the wrong one for the camaro
whoa chimera I'm sorry I didn't explain it right I worked all day last night,then went to work my other job,so me as a Christian I'd appreciate it if u don't use the wtf and be patient with ppl,we are all on a team on this website to help each other out!!!! And not say insulting things to each other please. God bless you sir.....
It sounds like you have resolved your issue and Fred or Robs advice is always gracious and spot on
Good luck
no problem man,it's ok I just wanted to make sure u were not related that to me,i was so exhausted writing that,n I know I probably didn't explain it right. And I already solved it,air was coming out of the coupler of the maf,and I really appreciate any information u put in the threads. Thank u man
