No power to PCM, HELP!!!
With the key on, engine off, the SES light is not illuminated. I have power to all fuses and relays, fusable links are ok. No power to the fuel pump relay or fuel pump. Wiring Diagram for the PCM anyone? Need to figure out which wire to the PCM is power, and no, shoebox doesnt have it.
ok, shoebox updated recently. But where does the PCM Battery Feed cable, come from. as in where does it hook up to the juice? Wiring schematic would be great here if anyone has one.
PCM BAT fuse. I meant to say previously, that the part of the PCM that powers up when you turn the key is via the ignition switch. The PCM BAT fuse sends power to the PCM at al times. Feeds through the orange wire in cavity C of connector C210 under the RH kick panel.
HEY, one guys saying left, one is saying right, there are smileys coming out of left field!
lemme get this straight, the PCM battery fuse, the wire from that, goes to the RH kicker, correct?
