No Power :(
Old Feb 6, 2006 | 10:46 AM
guitarguy20in's Avatar
No Power :(
Hey all im having a bit of trouble with my car. First of all it starts hard and idles rough, but it really starts to idle rough when I put it in any gear. At a stop the rpm's will jump up and down from around 1200 to 800 and back up. The car shakes like crazy. Take offs are horrible, for the first couple of seconds, it is slow and backfires a bit. I had GM put on a whole new distributor and changed the plugs/wires. (I was having this problem before, I thought it was the opticrap) What are the chances of some of the injectors being bad?
oh btw its a 94z with 130,000 milies, and the only mods are a K&N cold air intake, and a Borla exhaust
PJ
Old Feb 6, 2006 | 02:43 PM
OBE1 95Z28's Avatar
Re: No Power :(
Verify you have proper fuel pressure. Did you inspect your spark plugs?
Old Feb 6, 2006 | 02:44 PM
OBE1 95Z28's Avatar
Re: No Power :(
Also verify that the coolant temp sensor in the waterpump is functioning.
Old Feb 6, 2006 | 02:48 PM
BlownF1's Avatar
Re: No Power :(
Try unplugging the MAF also...
Old Feb 6, 2006 | 02:56 PM
Z28LT1_Just_Nasty's Avatar
Re: No Power :(
May have a clogged cat, hit it with a stick and listen for anything rattling around.
Old Feb 6, 2006 | 03:22 PM
Daniel6718's Avatar
Re: No Power :(
sounds like plug wires are mixed..check them
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
