No oil pressure when idle
Old Jun 30, 2003 | 12:14 AM
nastyntimber's Avatar
I just bought a 1994 Z28 with 27000 miles on the engine. I drove from Florida to Arkansas and it ran like a top. The oil pressure was around 30psi.
Problem: I changed the oil today and went with 10-30 synthetic Castor. When I started the engine, the pressure went up to around 50 psi. After let sit idle for 5 or so minutes, the pressure continuied to drop to almost ZERO. When I tap the gas, the pressure goes back to 20 instantly. When I let it sit idle for 5 minutes, the guage goies back to ZERO and the Warning light saying "CHECK GUAGES" comes on. When driving down the road the oil pressure runs between 20-30psi. The engine is leaking no oil whatsoever. What's up with this? Please help if you can. I am not a mechanic so I can't answer a lot of the technical questions.
Thanks in adavance.
Old Jun 30, 2003 | 12:27 AM
jasons93z's Avatar
it could be the oil pressure sending unit?
Old Jun 30, 2003 | 12:28 AM
O2Bsogood's Avatar
Welcome to the board. I'd say do a search about this, i think this kind of question comes up quite often. BTW, where ya at in Arkansas.
Old Jun 30, 2003 | 12:35 AM
I live in Pine Bluff, not proud of it, but my house is paid off. That leaves me a little more money in my pocket to leave here on the weekend.HAHA
The engine still runs fine, the pressure is just unbareable to me. It makes me think something is seriously wrong. I will try and get a new oil sending unit tomorrow and see what happens. This is the first time this car has had synthetic in it. Do you think that is the problem or what?
Old Jun 30, 2003 | 01:58 AM
94FlamdS10Blazr's Avatar
im betting on the sending unit also. I took 3 days off of work trying to replace my pump after my gauge dropped to 0 one night. I fought it on the ground, in the rain, by myself, with no hoist, jacking the motor up with a floor jack and 2x4s. After all that, it was the sender
Old Jun 30, 2003 | 09:15 AM
IrocManiac's Avatar
More than likely its the sending unit...
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
Cam's maro
Mar 24, 2015 08:09 PM
transam_388
Mar 15, 2015 11:53 AM
jayblev95
Dec 1, 2014 06:55 AM
