No gasket between Opti and timing cover??
Old Mar 11, 2005 | 07:02 AM
CheshireCat's Avatar
Question No gasket between Opti and timing cover??
I'm in the process of replacing plugs/wires/opti/water pump and I noticed when I removed the opti that there wasn't any gasket of any sort (unless dirt and grime count) between the Opti and the timing cover. I don't know why, but it seems like there should be one there...
Is there a reason that there isn't a gasket between the Opti and the timing cover??
Would anyone suggest creating a gasket (rtv) to keep out moisture/ dirt/etc??
Steve
Old Mar 11, 2005 | 07:13 AM
Re: No gasket between Opti and timing cover??
There should be a gasket in the timing cover around the opti drive shaft. That's all there is.
Old Mar 11, 2005 | 07:25 AM
Thank you sir... I guess other than around the opti drive shaft, no other gasket is necessary...
Thanks again,
Steve
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
nophix
Nov 30, 2014 10:26 PM
