NO! did i just F**% myself!
Old Jan 15, 2004 | 01:08 PM
93transam1234's Avatar
I just changed the oil and put in 6 quarts instead of 5 now my oil presure when it is hot is only like 15!
But on the good side when i first start up the car the presure is stead at 45-50 and when driving it is around 40
DID I HURT ANYTHING? I will drain the extra out ASAP
anythin else to do? or check
Old Jan 15, 2004 | 01:11 PM
FacelessZ's Avatar
No you should be fine...just get the extra quart out of there...
Old Jan 15, 2004 | 01:15 PM
Tony Danza's Avatar
what are the biggest dangers of having too much oil? other then oil finding its own way out
Old Jan 15, 2004 | 01:27 PM
Rodrigues's Avatar
Blowing seals, rear main seal mainly...
Old Jan 15, 2004 | 01:29 PM
FacelessZ's Avatar
Just more prone to leaking as stated above...
Old Jan 15, 2004 | 01:58 PM
Dan Oldham's Avatar
Floating valves.
Old Jan 15, 2004 | 02:05 PM
ibanez6rg's Avatar
It's not good to have too much motor oil in a motor. Get rid of the extra quart.
Old Jan 15, 2004 | 02:42 PM
RE AND CHERYL's Avatar
Cool
Been there, Done that!
Other than causing the rear main to possibly leak, it won't hurt anything. The main problem will be the crank will be running in the oil and will act like a blenderpumping air into the oil and further raising the level. Just pull the drain plug for about 1.5-2 seconds and put it back in, then recheck oil level.
