No coolant flow LT1
Old Jul 10, 2018 | 11:36 AM
Oysteinbno's Avatar
No coolant flow LT1
Hi.
My engine overheats and build pressure. I have this engine in a Hot Rod and i hope someone have a solution for me.
It seems like the water pump is not flowing. The pump is new, and the thermostat is new. I have bled the coolant system and I am pretty sure there are no airpockets anywhere.
I removed the front of the waterpump to check that it turns, and it does. I have removed one of the heater hoses to see if the water flows, but no flow. So I am really stuck here.
Oysteinbno
Old Jul 10, 2018 | 01:55 PM
Shadyredeyes's Avatar
Re: No coolant flow LT1
Any chance you bought a reverse flow pump by accident?
Old Jul 10, 2018 | 02:42 PM
BIG SHAFE's Avatar
Any chance the radiator is old/blocked?
Are you sure the thermostat is opening?
Old Jul 10, 2018 | 03:03 PM
Did you check the water pump driveshaft coupling?
http://shbox.com/ci/water_pump.jpg
Is the thermostat the correct one for an LT1 engine:
http://shbox.com/1/tstat.jpg
Thanks to Shoebox for the graphics.
Old Jul 11, 2018 | 01:18 AM
Oysteinbno's Avatar
The pump is for a LT1 Corvette 93-97 so the pump should be the correct one.
Old Jul 11, 2018 | 01:19 AM
Oysteinbno's Avatar
The radiattor is open and flowing good, and i have tested the thermostat in boiling water.
Old Jul 11, 2018 | 01:25 AM
Oysteinbno's Avatar
The coupler fits on the shafts on both sides. I have removed the front cover on the water pump and turned the engine, and the water pump is turning.
But still no flow when put together and filled up with water.
Also tried to disconnect a heater hose to see if I have flow there, but nothing..... It's a real mystery
Old Jul 11, 2018 | 07:45 AM
BIG SHAFE's Avatar
I'm confused, so which lines are flowing and which ones aren't?
Old Jul 11, 2018 | 10:18 AM
lt1-xjs's Avatar
A little more info is needed, motor year, type of radiator, how the heater hoses and steam line are connected. Some ports will need plugged.
Old Jul 11, 2018 | 02:32 PM
Oysteinbno's Avatar
The engine is from a 1995 Corvette, so it's a LT1.
The steam line is connected to the hose from the top of the waterpump up to the radiator. The lower heater outlet on the waterpump is connected to the line with the heater regulator an the top are connected to the return line from the heater.
I use a 3-row aluminum radiator that fits the body of the car (1936 chevrolet ). Inlet on top left, and outlet at the lower right.
I believe that it should be flowing trough the steam line all the time, but I have abolutely no flow. The heater hoses become hot, and from the waterpump to the radiator. The lower part of the radiator is cold. After a while the water starts boiling..
Old Jul 11, 2018 | 06:16 PM
The Corvette coolant system is significantly different than the F-Body (Camaro/Firebird), particularly with regard to bleeding the air out of the system. The Corvette system “self bleeds”, the F-Body system needs to be manually bled.
Here's the way a 95 F-Body (Camaro/Firebird) should be connected, with arrows showing flow directions. The flow from the back of the heads (steam pipe) should pass through the throttle body, then enter the liquid/vapor separator in the radiator. You appear to have it entering the pump suction (feed line) from the radiator to the water pump. Putting hot coolant and vapor bubbles into the pump suction may promote cavitation.
http://shbox.com/1/95-97_hoses.jpg
The Corvette water pump is also slightly different than the F-Body pump, mainly with regard to orientation of the connections. The functions are still the same.
http://shbox.com/1/lt1_water_pumps.jpg
Do you have a heater, utilizing the connections on the water pump? Do you have a flow restrictor in the supply line (part #13 in this diagram):
http://shbox.com/1/heater_hoses.jpg
Do you have an oil cooler?
Graphics courtesy of Shoebox.
Old Jul 12, 2018 | 01:02 AM
Oysteinbno's Avatar
The steam line is connected at the pump feed line, so that should be right.
I don't have a flow restrctor. This is only used to prevent to much cooling when cold outside. This is not a problem since I use the car in the summer.
No, I don't have an oil cooler.
Old Jul 12, 2018 | 10:36 AM
Since you appear to totally reject my analysis, and feel you have a full understanding of the purpose of the flow restrictor, I'll drop out at this point.
Good luck.
Old Jul 13, 2018 | 01:30 AM
Oysteinbno's Avatar
I have a shutoff valve in my heater system, so I don’t need this restrictor valve
And I ’m sorry that you think this way. Thank you for your tips/questions so far
Old Jul 16, 2018 | 08:06 AM
lt1-xjs's Avatar
https://www.camaroz28.com/forums/lt1...outing-881977/ Look at post 6 for the diagram and post 10 for the routing. If your filler neck is the highest point you should not have to bleed the system, just use a standard overflow tank.
