Nitrous on Stock Rear
Old May 26, 2003 | 02:27 AM
ollie-99's Avatar
and mods in sig using stock rear end
would it hold up?!
Old May 26, 2003 | 03:09 PM
norcalstreet's Avatar
I'm surprised it's holding up with the mods you have now!!! With a six speed you're looking to blow up your rearend. Start saving for a 12-bolt IMHO.
Old May 26, 2003 | 03:14 PM
Josh-'04 GTO's Avatar
Actually you're in no real danger as it is. The key right now is that you are running street tires, not slicks. As long as you are running radials, make as much power as you want. The tires will spin before your axles/gears will snap. Nitrous + slicks + M6=12-bolt time!
Old May 26, 2003 | 03:22 PM
HardcoreRM125's Avatar
lol do yourself a favor and dont spray off the line ... I know a kid in 11th grade who is NOS crazed , put it in his 92 Z, with a 100 shot i think? Hit it off the line as he lauched and it decimated his driveshaft
Old May 26, 2003 | 11:45 PM
Joe Brodman's Avatar
GP Moderator
I spray off the line.
As long as you don't hook, I say it should be fine. I was running mid 12's on the spray and internally stock w/ my stock 10-bolt....held up fine, and sold it in working order. I went to the 12-bolt so I could run sticky tires and launch a lot harder.
Old May 26, 2003 | 11:46 PM
GP Moderator
Old May 27, 2003 | 05:22 PM
Oh , I didnt think the stock 4th gen rears could handle that , thats cool tho that they can. I guess maybe his Camaro has a weaker shaft & rear since its a 3rd gen and not 4th ? ... What shot were you using on the stock rearend ?
Old May 27, 2003 | 05:26 PM
Hawk's Avatar
i broke my rear 2 months after i had the juice
Old May 27, 2003 | 05:41 PM
funina91ss's Avatar
you caint really base it on who has and hasnt broke theres I put a 6 speed in my 305 TBI camaro and it will snap a 10 bolt like a match stick, on the street with street tires. with a little help of a spec clutch . It now has a 12 bolt so no more rear breakings.its more in how you drive one. if you power shift alot and stuff like that.
HectorM52
Jul 30, 2017 11:46 AM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
