ngk tr55 gap size?
Old Aug 31, 2004 | 04:35 PM
camzaro28's Avatar
ngk tr55 gap size?
could anybody tell me the gap size i should run with these plugs? dont they come .40? thanks in advance
one more? when doing wires someone told me there is a hole in the block, and that would make it easier to route my wires! does anyone know what im talkin about?
Old Aug 31, 2004 | 04:44 PM
sabre81's Avatar
Re: ngk tr55 gap size?
They should come gapped at .50 which is what you want. Check with a feeler gauge just in case they got banged around. And there is no hole in the block to route wires, use stock looms.
Old Aug 31, 2004 | 07:06 PM
Camerone222's Avatar
Also, in case you forget again, it says what the gap should be when you open up your hood, look at the radiator shroud.
Cameron
Old Aug 31, 2004 | 09:38 PM
OBE1 95Z28's Avatar
There's no hole in the block to route wires. What they probably meant was on the passanger side, you can route the wires behind the accessory bracket, as there is a space or "hole" between the block and the accessory bracket. This is handy if you run aftermarket wires that are thicker than the stock 7.5mm wires as the thicker wires are tough to properly capture in the stock holders.
Old Sep 1, 2004 | 02:53 AM
'97SLVRBullet's Avatar
97 z28 auto, k&n cai, bfgoodrich kdw, *160 thermo, 3" cut-out, lt4 km, tb bypass, msd ign!, msd coil, *madz28 tune*, rebuilt tranny, tci 2800 stall, transgo shift kit, bmr sfc's, taylor 8mm, NGK tr55
best times to date 14.1@98.9
What I want to know, is how are you not breaking 14's? I ran that bone stock. If you're ever around Texas let me know...I got to see your car. We may be able to help?
Old Sep 1, 2004 | 07:58 AM
camzaro28's Avatar
my times blow! that time i ran b4 stall,tune, plugs, and sfc's! i think my opti is goin, my car idles like crap. that is y i am doing the plugs now and if that dont fix it then i am goin on to the opti!
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
Jake Bialke
Sep 24, 2015 11:31 AM
colts0455
Sep 11, 2015 06:16 PM
Slayer
Aug 17, 2015 03:55 PM
