Next mods....
Old Apr 8, 2003 | 05:26 AM
1982z28with18s's Avatar
Next mods....
This is for my friend with a 95 T/A with CAI, catback and cutout as only mods.
He is doing this project in two waves, simply because he cannot afford them all at once.
He needs some help deciding what cam to go with. He really doesn't want the hotcam.
First wave:
Hooker Jet hot Coated Long Tubes
Comp Cam (possibly custom grind)
Valve springs
Retainers
1.6 Rockers
Taylor Wires
New Spark plugs
Fix the intake leak
Second Wave:
Vig Stall Convertor (size?)
3.42 gears
Tranny Cooler
Nitto's
Some one want to help him out. He ran a 14.3 with 2.2 60ft stock, and a 14.1 with a 2.1 60ft two weeks ago with his current mods. What times do you think he will run after the 1st wave and then after the 2nd wave. Also, what rwhp do you think he will be putting down after the 1st wave.
Old Apr 8, 2003 | 04:29 PM
Dragon Racing's Avatar
I would go with the headers next. And while you are doing that, go ahead and do the plugs and wires b/c that will be the easiest time to change them.
Old Apr 8, 2003 | 04:38 PM
qwick_trip's Avatar
do a search on what cams people are using. also don't for get to get cromoly pushrods two. there expensive put your gonna need if you plan on taking the rpm's up.
Old Apr 8, 2003 | 05:35 PM
Thanks for the ideas.
Old Apr 8, 2003 | 05:48 PM
mineralwater's Avatar
while he's doing the rockers, he should also do a cam. both 1.6RRs and valvesprings, with a hotcam can be had for $450, btw.
Old Apr 8, 2003 | 11:03 PM
Umbrae's Avatar
I think your buddy should do some maintanence type things first, because 14.1 with an intake, and cutout seems kinda slow. Fix the intake leak! Get those long tubes and do plugs and over the valve cover wires at the same time. Should feel like a whole new car.
Old Apr 9, 2003 | 02:45 AM
chesee48's Avatar
lowest stall i'd get would be a 2800...
Most i'd go would be 3200...some say 3600 but you'll run into some pcm problems, that can be fixed though by pcmforless.com
Thats JMO, but i had bought a stall that was a restalled Vig 3000, so im right in the middle
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
stockLT1
Apr 19, 2004 07:14 PM
