Next Modification.
Old Sep 11, 2008 | 02:50 PM
1FstFormulaV8's Avatar
Next Modification.
I'm having a hard time deciding on what I should to to the Formula next. I recently installed a Moroso CAI. I want the next mod to give me a little more omph! My choices are a 1LE intake elbow and a 52MM Throttle body. My elbow is badly torn and in need of replacement. My next choice would be a set of 3.73 gears.
I'm not getting a catback because I have plans on doing LT's and True Duals.
Which of these will yield a better punch. Gears or elbow+TB?
Old Sep 11, 2008 | 02:59 PM
slomarao's Avatar
Elbow- 60 bucks and a few hp, TB is 325 and a few hp. you pick.
Next i would get a pcm tune. They are 75-125 and will be worth 10-15hp because the factory tune is so rich. After that get the gears, or do them both have have you speedo corrected.
I would really look into a set of headers. THey are 500 roughly for all the parts needed but well worth it.
Sinister95Z's Avatar
Out of those choices, the gears will give you the most seat of the pants improvement. Niether the elbow or TB will give you much of an increase, especially a very noticeable difference like you are looking for.
Old Sep 11, 2008 | 03:02 PM
I can order a set of Pacesetter LT's coated. For around $400 through work. A tune has ran across my mind. I'de like to have that after all the bolt ond are in place.
Old Sep 11, 2008 | 04:59 PM
lt1-xjs's Avatar
The elbow, exhaust, tune, gears and a Yank SS 3600 is the order I would do.
Old Sep 11, 2008 | 05:13 PM
chevy94c's Avatar
I agree
Old Sep 11, 2008 | 05:15 PM
bombebomb's Avatar
Be kind of dumb to get a tune before the gears or converter, id get the tune last. asuming hes going to do this all somewhat quickly.
Old Sep 11, 2008 | 05:41 PM
slomarao's Avatar
or he could get the tune first and have it re tuned for free???
Old Sep 11, 2008 | 06:17 PM
lt1stroker's Avatar
Not to thread jack, but where can i get my speedo corrected, i have 373s and 2200 stall and the speedo is of about 5mph?
Old Sep 12, 2008 | 07:21 AM
2000GTP's Avatar
The elbow won't add any power gains, and neither will the TB with the mods already done. I would do the gears for now.
Old Sep 12, 2008 | 11:02 AM
slomarao's Avatar
pcmforless for the speedo. A tune will fix it.
Old Sep 12, 2008 | 01:28 PM
MTBSully's Avatar
stock tb really isnt restricting until almost 400whp. so i would def go for elbow.
Old Sep 12, 2008 | 01:31 PM
MeanGreen97Z's Avatar
elbow + tune....
Old Sep 12, 2008 | 05:38 PM
slowride94z's Avatar
still got to hook them up $$$
Old Sep 12, 2008 | 08:16 PM
karpetcm's Avatar
Gears all the way, elbow and tb will not give you much at all. No doubt you will feel the difference with gears which will make your car quicker and more fun to drive.
