Newly rebuilt engine, open long tubes possible to burn an exhaust valve
Old Apr 21, 2003 | 09:53 AM
Chuck2's Avatar
I rebuilt the engine and put hooker long tubes on it but now i dont have any money to put custom exhaust on it. I need to break it in right first which im told it should run for about 20 minutes at various rpms. Then after that i have about a 15 minute drive home. Will this burn an exhaust valve because it is a fresh engine?
Old Apr 21, 2003 | 12:43 PM
JucinGTA's Avatar
No man its all good, with LTs you will have enought backpressure, you will be fine. If you want to go the cheap route and be safe go buy 2 cherry bombs 10 bucks each and that will help ya out.
Old Apr 21, 2003 | 01:44 PM
Chuck2's Avatar
does anyone disagree with this If not then Im gonna try it
Old Apr 21, 2003 | 01:49 PM
teke184's Avatar
yeah i'd just clamp a couple feet of 3" pipe to each collector, will make sure you don't hurt the valves and it will keep the heat away from the fuel lines and things for safty.
there are many guys running cutouts right off their LTs
Old Apr 21, 2003 | 01:55 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
your fine,
id highly advise against open manifolds or something though.
the valve wont "burn," its stainless steel (usually)
it can withstand an insane amount of heat.
with open manifolds or something you run the risk of warping it slightly when cold air rushes in there after you shut the car off
LT14LIFE
Feb 9, 2015 09:35 PM
Jan 5, 2015 07:14 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Queens94z28
Nov 20, 2014 06:03 PM
Jul 4, 2005 05:00 PM
