newbie question on stall converters
Old Mar 9, 2004 | 08:22 PM
CamaroSS30thAnn's Avatar
What is the advantages and disadvantages if any on using a higher stall.......??
How does it help u the quarter mile??
Old Mar 9, 2004 | 09:40 PM
TTT
Old Mar 9, 2004 | 10:39 PM
S.J.S.'s Avatar
Well, you'll have better lauches, provided you get a dead hook. As for disadvantages.....you'll loose gas mileage because your car will lag in the lower r's. Some guys have problems with stalls over like 3200.
This all depends on how high your talking about.
Old Mar 9, 2004 | 10:44 PM
Green95Z28's Avatar
One of the main advantages is allowing your engine to rev to a higher RPM before it starts moving the car. This allows you to taking advantage of your higher rpm torque. A good converter will yield HUGE gains in the the first 60 feet at the dragstrip. On the street, well, your tires won't like you
One of the main cons is that it generates a lot more heat in the transmission fluid. If you don't go too aggressive with it, I am not an a4 guy so i don't know what people usually run, my guess would be like 2500 - 3000 stall speed on the street. This stall wouldn't be that hard on your transmission.
Basically it will, get your car moving by taking more advantage of your engine's rpm and you will accelerate MUCH faster off the line.
Old Mar 10, 2004 | 05:12 PM
thanks man i had that pretty much figured out.....just wasnt too sure.....thank man
marine1bird
10
Jan 25, 2015 12:02 AM
Z28countrymama
Jan 22, 2015 02:50 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
mysticslp2002
Jul 29, 2002 02:03 PM
