new z28 owner
Old Nov 17, 2003 | 08:34 PM
pbpube's Avatar
new z28 owner
ive got some questions. im a new owner, so i know just some basic stuff about my 96 z28 (5.7L). first, whats the HP rating on it? i dont know if this is close, but im guessin around 300? also, it runs hot. when cruising, it stays close the the mark b/t the middle/ideal temp mark and the overheating mark. and when sittin at stop lights it starts heatin up more. is this normal, or do i need to flush the radiator or what? theres also some minor rattling goin on in places, so where is a recommended place to take it to get that fixed?
Old Nov 17, 2003 | 08:36 PM
FacelessZ's Avatar
If you look at the bottom right of the LT1 Tech page you'll see a small box...it's called a search function...type in whatever you'd like to know and it'll pull up past posts...
Good luck!
Old Nov 17, 2003 | 08:39 PM
Kataklysm's Avatar
Your car is rated at 275 HP. A new thermostat will make the car run cooler, flushing the cooling system will be good so you may as well do it anyways.
Old Nov 17, 2003 | 08:40 PM
Heatmaker's Avatar
Advanced Member
HP rating= 270-275 or worse depending upon mileage
It runs hot...get the Coolant changed and install a new lower degree thermo...or try bleeding out the Coolant system first. It should be a tick below the center mark...that's average.
minor rattling goin on in places--common... These cars have allot of chassy vibration and bolts and things tend to loosen up. Main bolts..(exhaust) since you have Borla. I have the same and I'm tightening bolts every other day.
Old Nov 17, 2003 | 08:41 PM
FacelessZ's Avatar
A 160* stat + tuning will help your car to run cooler...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CamaroHeed
Mar 18, 2020 09:50 PM
cmdeshon
Jan 4, 2015 11:15 AM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
