New Water Pump probs
Old Aug 28, 2004 | 06:30 PM
1970AAR's Avatar
Well, after having a problem with the car overheating due to a loss of coolant from the system, I replaced the water pump and the temp went right back down to normal levels. However, after examining the car again this afternoon, there is still a constant drip of coolant that looks to be coming from between the block and water pump. What could be still causing that drip? Does the water pump need to set or something (I did replace the gaskets/seals with the new WP)?
Any help would be greatly appreciated, I want to deal with water pump/cooling problems as quickly as possible.
Thanks,
Tom
Old Aug 28, 2004 | 07:25 PM
WickedLT1's Avatar
Re: New Water Pump probs
This may sound simplistic, and don't take offense, but did you use gasket sealer? What type? As well as on the bolts? The only other thing that I can think of is... Did you get all the old gasket material off of the block surface?
-Paul
Old Aug 28, 2004 | 07:59 PM
1970AAR's Avatar
Yup, used gasket sealer, and removed the old gaskets (2) from the assembly first..but I'm taking it apart again tommorow if it still hasn't set and stopped leaking.
Old Aug 28, 2004 | 09:57 PM
You used thread sealant on the bolts?
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
