new starter, can't get it to work smoothly
Old Sep 25, 2005 | 03:15 PM
KeVMaN's Avatar
My starter went out, and i put on a new one from autozone. it's a bronze color, and slightly smaller/different shaped than the old one, but it had a piece of paper in ther with it that says "this starter looks slightly different than the original but will perform better" or something like that, so i figured it was fine. I bolted it in and when i start i hear a high pitched grinding noise. we tried putting 1-4 shims in there, shimming one side, everything we could think of and we can't get the thing to quiet down. what should i do?
Old Sep 25, 2005 | 03:24 PM
MENEGRANDE's Avatar
Re: new starter, can't get it to work smoothly
i had the same problem, return it and get a lt4 or a ac delco
Old Sep 25, 2005 | 03:30 PM
KeVMaN's Avatar
damn that sucks. Do you know if they have the right deal at autozone? if i return this then i won't have a core to take back
Old Sep 25, 2005 | 03:56 PM
Dave89IROC's Avatar
bitch that you want your core back
Old Sep 25, 2005 | 08:52 PM
TransAm9585's Avatar
I had the same issue. The remaned starters are junk. Go to NAPA or somewhere else and get a New one not remaned. The remaned ones i bought all whined and had to be returend.
Old Sep 25, 2005 | 10:13 PM
OBE1 95Z28's Avatar
I read if you buy a LT4 starter from GM they don't require a core. Check with Dal or Jason Cromer.
eazyZ
Mar 1, 2015 07:12 AM
Fatdog2
Feb 13, 2015 08:19 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Brake_L8
Jan 20, 2015 09:44 AM
Jeff1904
Jan 3, 2015 12:00 AM
