New Rebuild Problems
Old Feb 6, 2008 | 01:29 PM
  #16
ss.slp.ls1's Avatar
Good to see that you got it going. Looks like you have a whole new ignition system now . Did you use a generous amount of RTV on the front and back of the intake manifold? That's a common oil leak source, good luck.
Old Feb 6, 2008 | 07:05 PM
  #17
asia517's Avatar
I think the leak is coming from the oil presure sensor behind the intake manifold. Also later in the day i went to start it again and see if I fixed the oil issue and it just turned and turned but didnt start. so I went back to the same ground wire, I found that the copper connector is melting and getting groves in it. So I tried to ground it even better than before then tried to start it again and it did but wouldn;t stay running, after a few tries I am now back to getting nothing except turning. PLEASE someone HELP... note; this car has been siting for 5 years.
Sergio
Jan 27, 2016 04:27 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Jazsun
Dec 29, 2014 12:14 PM
