new rear end cause traction and abs lights to come on?
Old Jun 20, 2003 | 01:06 AM
ponykiller z28's Avatar
i recently did a v6 to lt1 swap in my car without swapping rear ends so as we all knew it would tear up, it tore up....so i put a new posi trac rear end (3:23) (stock v8) in it and now every time i hit the breaks my low traction light comes on and then my ABS light comes on......
what is causing this?
please reply with any suggestions..
thanks
Old Jun 20, 2003 | 05:33 AM
slopokrodrigez's Avatar
It's probably in the rear wheel sensor circuit in the rear end. Scan it to be sure. Usually after break in, metal particles will adhere to the sensor. Take the cover off and see if filings are stuck to the inside of the sensor. If that's not the problem and the sensor is good then the problem is the clearance to the reluctor ring.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
squarehead
Jan 15, 2015 07:02 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
