New plugs, wires, opti, coil, ICM and still a hesitation when cold at low rpms??
Old Aug 3, 2003 | 04:16 PM
TexasTechTA's Avatar
When the car si warming up for the first couple of minutes there is a hesitation if I give it over half throttle at low rpms. I know my AF is lean could this be the pcm sensing knock and retarding timing? also I have amaf code that says insufficent activity could it be this let me know thanks.
Old Aug 3, 2003 | 04:56 PM
thebadone's Avatar
I have miss and hesitation also....
I have changed my wires and plugs, and coil. I get a miss when it warms up. If you find the solution to your problem email me at kaylin11@comcast.net
Old Aug 3, 2003 | 04:58 PM
jasons93z's Avatar
have you changed you fuel filter? I had a similiar problem and it was cured with an ORP(cat was clogged), new fuel filter, and new coil. Good luck
Old Aug 3, 2003 | 05:03 PM
I havenot done the fuel filter what two sized wrenches do you need to undo the fuel line is it 5/8 and 11/16?
Alex Barnes
Jan 24, 2015 10:21 PM
Jazsun
Dec 29, 2014 12:14 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
