New parts!
Old Jun 23, 2006 | 12:37 AM
Josh3111's Avatar
New parts!
I got my hot cam kit, CSR elec pump, and extreme LT4 timing set.....any suggetions before I install this...oh and I got all the gaskets....anyone that has done this may have some good advice...???>>>
Old Jun 23, 2006 | 08:00 AM
MEAN LT1's Avatar
Re: New parts!
Take your time. Buy beer
Old Jun 23, 2006 | 08:12 AM
MeanGreen97Z's Avatar
Re: New parts!
Beer is definately a needed item! Don't start this project without proper drinks and snacks. LOL But seriously I'd make sure to clean all the parts really well and inspect them before tearing things apart. Make sure you got some assembly lube and you should be good.
Old Jun 23, 2006 | 01:39 PM
seawolf06's Avatar
Re: New parts!
Label everything! Including all the connectors and plug wires to save time. Clean all bolts/threads as best you can, best thing is to get a thread chase set. Use lots of RTV and try your best not to rip the oil pan gasket. Don't hammer on the crank sprocket. I'll have pics up soon of what I used. Don't use the crank bolt to turn the crank without the hub on or some kind of spacer, it will bottom out and mushroom. Make sure you read shoebox's removal and install guide all the way through and make notes on what you need before you start, especially if you don't have another car to drive, luckily I did cause I went to the hardware store sometimes 3 times a day. Good luck.
Old Jun 23, 2006 | 01:59 PM
Colin91Z's Avatar
Re: New parts!
I have a friendly suggestion
Send that extreme LT4 timing set back and get a standard cloyes double roller (since you don't need the waterpump drive gear any longer due to your CSR water pump) and use the $200 you just saved to buy more mods (not to mention that you'll have a much better timing set than the ED LT4)
Old Jun 23, 2006 | 02:06 PM
seawolf06's Avatar
Re: New parts!
I would have suggested that as well if you hadn't already bought it.
HectorM52
Jul 30, 2017 11:46 AM
novaiiman
May 15, 2016 11:36 AM
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
