New oil pan and pick don't fit??
Old May 25, 2005 | 02:48 PM
RacerTim's Avatar
Just bought a new Milodon oil pan with a built in windage tray and the corresponding pick from summit the other night. With the new pickup installed it hits the windage tray when i try to install the pan. Would I be hurting anything besides my chances of returning the pan if I cut a little bit of the pan out?
Summit parts numbers are:
Pan:
http://store.summitracing.com/defaul...=egnsearch.asp
Pickup:
http://store.summitracing.com/defaul...part=MIL-18307
Old May 25, 2005 | 03:12 PM
The Cartel's Avatar
Re: New oil pan and pick don't fit??
Nope.. I'm running the same thing. I sectioned it out a little, cleaned up the edges and it works perfect.... Go ahead and tack weld your pickup tube in the oil pump though. I did, I've had one work loose and fall out before...
Jason
Old May 25, 2005 | 03:14 PM
RacerTim's Avatar
The pickup bolts to the oil pump housing, wont that be good enough to keep it from falling out? Kinda lacking a welder here.
Old May 25, 2005 | 03:19 PM
The Cartel's Avatar
Not sayin they won't work, jus that I like the security of havin it welded. Pull the pump , take it to an exhaust shop. They'll hit for a couple bux...
Old May 25, 2005 | 03:50 PM
RacerTim's Avatar
Awesome. Took less than a 1/4 in off and it fit perfect. Just like to check things out before I start cutting apart brand new stuff. Thanks Cartel.
Old May 25, 2005 | 05:58 PM
1racerdude's Avatar
Thats the way it should be-- Welding it ya chance warping the end plate which leads to a not so good pump.
HectorM52
Jul 30, 2017 11:46 AM
Sandersen511
Jan 13, 2015 03:49 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
