New o2s is this right? Pics inside
Old Mar 6, 2008 | 11:11 AM
krillformula's Avatar
I just bought 2 new o2s and they dont look the same? Should it be like this or is one of them wrong? They are booth AC Delco and booth has the AFS75 partnumber which I believe is right for my car.
You can see the difference here
They did come in different package, the one in the middle came in the box to the right.. But still same partnumber
Thanks!
Old Mar 6, 2008 | 11:23 AM
Ratlor's Avatar
When I bought my front O2 sensors they both came in the package on the left. My assumption is that the one on the right is just a different design, be it older or newer, that they happened to send you. If you have a real doubt about the sensors, I would contact who you bought them from.
Old Mar 6, 2008 | 11:28 AM
Thanks, if they are the same just different design then no problem for me. Just want to make sure it´s ok to use them. Guess I will contact where I bought them from, just wanted to check with you guys if someone knows for sure!
Old Mar 6, 2008 | 11:44 AM
JeremyNYR's Avatar
I just bought a pair at autozone and there was one of each design in identical boxes. I didn't like the fact that they didn't exactly match, so I had them get another one so I had a matching set that looked like the ones in the left of your picture. I think I chose that one because it was a little shorter and wanted all the clearance I can get with my LT1 into 3rd gen swap.
Old Mar 6, 2008 | 11:50 AM
Was that ac delco also? I feel the same, kind of dont like that they doesent exactly match Would have been much easier if I just got 2 of the same
Old Mar 6, 2008 | 12:20 PM
ssbowtie1's Avatar
I used to have 2 of the ones on the left. I just ordered a new pair about a month ago and got 2 of the ones on the right. I'm sure they're interchangeable, afterall they're both going to output the same parameters.
Old Mar 6, 2008 | 02:28 PM
Nice! Makes me feel better about them. I guess as long as they are delco and have the correct partnumber on them I should be fine.
Old Mar 8, 2008 | 09:37 AM
Jeffs94Z28's Avatar
The one on the right looks like a Delphi new style.
Old Mar 8, 2008 | 04:35 PM
Should be equal then! Thanks
NewsBot
May 15, 2015 10:10 AM
cmsmith
Mar 16, 2015 02:34 PM
rjc1629
Jan 27, 2015 10:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
omarECD
Aug 19, 2002 07:28 AM
