new NGK iridium plugs(1 range colder), good for juice??
Old Sep 21, 2004 | 12:28 PM
Hawk's Avatar
Quick question, I know plats aren't good for nitrous, I'm using a 100 shot. I use the NGK tr6 now and they need to be repalced, NGK now has the iridium plugs that are also one heat range colder. ARe these good for juice, or are they like plats and they shouldn't be used??
Brian
Old Sep 21, 2004 | 06:10 PM
Hawk's Avatar
Re: new NGK iridium plugs(1 range colder), good for juice??
TTT, already emailed thunder racing no reply yet, any help??
Old Sep 21, 2004 | 07:52 PM
80TA's Avatar
Platinums are the ones that are not supposed to be good for nitrous.And copper plugs don't last long.I think the iridiums should be great and seen lots used by the import guys with big turbos and spray.Also in additon to the ngk iridiums which up till now were in stock heat range only you can order denso iridiums in several heat ranges lower.They are virtually same as ngk ones maybe a bit pricier but they have a long life.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Jazsun
Dec 29, 2014 12:14 PM
