New engine build -- quench question
Old Nov 26, 2007 | 12:22 AM
cvccbum's Avatar
So I bought a full forged setup, 9cc dish pistons.
Stock deck is 0.017 i'm assuming and i'm looking for 9.5:1 compression atleast.
to get that, i'd have to get a really thick gasket, but doing that makes my quench around 0.090.
They say .050 is the limit for a turbo setup.
What will be the downfall of having a quench this big? Will the engine not run correctly, and have poor performance?
Thanks!
Also: Lloyd Elliot told me stock CC of heads are 54.5 so i'm going off that.
Is there any possible way to utilize these pistons or do i need new ones?
Old Nov 26, 2007 | 12:33 AM
speed_demon24's Avatar
Did you measure the deck height? Most are .025-.030, mine came out to .020 when I measured it though.
Old Nov 26, 2007 | 12:44 AM
cvccbum's Avatar
Nah, haven't checked that yet, but I believe my quench will still be the same if i try to get the same CR since my pistons are 9cc dish.
Not 100% on that though.
Old Nov 26, 2007 | 03:44 AM
SS RRR's Avatar
The "quench" area will not be able to "quench" the last ignition charge leading to pre-ignition to hot spots to detonation to destruction.
Old Nov 26, 2007 | 10:37 AM
cvccbum's Avatar
I heard with forced induction, the quench really has no play. Is this true?
Old Nov 26, 2007 | 02:54 PM
FlamingChicken's Avatar
Im not an expert by any means but I would assume quench would play a larger role in a f/i setup. I believe one of the main benefits is cooling hot spots and preventing detonation. you could always get some tfs heads if you dont want to mess with the bottom.
oldschool
Feb 9, 2016 09:21 PM
Jrlt1
Jan 3, 2015 07:38 PM
Injuneer
Dec 15, 2014 09:36 AM
Bearmans
Dec 3, 2014 05:28 AM
squirrels
Jul 13, 2002 01:58 AM
