New clutch and now no oil pressure
Old Feb 1, 2007 | 12:29 PM
daruff's Avatar
I just got my car out of the transmission shop today, i had a new clutch put in. Well now i notice my oil pressure does not go above 10lbs. Do you think this is a coincidence or did they possibly break something? I have an appoinment for monday to take the car back so they can look it over.
What and where would i look for to make sure i am actually getting pressure and to determine whether it is a sensor or acually low oil pressure?
Old Feb 1, 2007 | 12:41 PM
hotheadbuddy's Avatar
alot of times when the trans is removed if they are not careful the oil pressure sending unit at the back of the intake manifold gets broken you may want to check it out to make sure before taking it back there. or a wire could be pinched between the tranny and the block hope this helps.
Old Feb 1, 2007 | 12:57 PM
Javier97Z28's Avatar
Moderator
Probably a broken oil pres. sending unit as noted above... try that first.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jul 4, 2005 05:00 PM
