New clutch installed, worked fine, now slips....
Old Nov 14, 2002 | 10:07 PM
  #16
DubbyZ28Camaro's Avatar
I talked to McLeod a while back and they just told me that I "Needed to do the drill-out mod" for the clutch to properly work. My response was "why in gods name wasn't that included with the instructions??" He gave me some BS answer and I just listened. Anyways, go to McLeodind.com and there should be a tech number at the bottom of the page. Call the number and the owner will either fax you instructions, or tell you what to do. It seems to work much better now, but they DO reccomend an aftermarket hydraulic system with a performance clutch....go figure, they tell me after I already bought the clutch.
My feeling is, if its gonna slip...i will let it until the *****er burns out and then it is time to get a Street Twin which comes with EVERYTHING that I need!!
Old Nov 14, 2002 | 10:14 PM
  #17
timelord's Avatar
I have found the cure,installing built A4 with Vig 3000 lock up,BMR extreme sway bar & HAL Shocks and Springs in front.
My 60 ft will be 1.60s and I should be in the 11.s and stop smelling underhood to see how my clutch did after every run.
Old Nov 14, 2002 | 10:22 PM
  #18
Unfortunately, thats a very expensive alternative!!!
Old Nov 14, 2002 | 11:02 PM
  #19
timelord's Avatar
We have INCREDIBLE prize money up for grabs next season,should not cost anything!!!!
Old Nov 15, 2002 | 12:10 AM
  #20
Achilles97's Avatar
Can't a new clutch start slipping early if it is not properly broken in?
How many miles are necessary before you really hammer it? What about full throttle acceleration but granny-shifts?
Thanks!
Old Nov 15, 2002 | 12:18 AM
  #21
timelord's Avatar
500 miles of stop and go driving!!!
Old Nov 15, 2002 | 10:07 AM
  #22
Achilles97's Avatar
500 miles, I know that's what the manufacturer says, but I've been told that 250 is fine with a normal, non-puck style clutch.
I've had my clutch on for 4 months and it only has 175 miles, and it's REALLY aggravating. I try to drive as much as possible but it seems like 500 will never come. When I had 135 miles, I did one 20-120 run, but I granny shifted... I hope it's alright. The clutch feels broken in, but there's no way to tell if the disc is glazzed over.
Old Nov 15, 2002 | 10:51 AM
  #23
timelord's Avatar
Do the 500,on the 1st I installed this summer said to myself,250 more than enough and went to the track.After changing discs,,,,,,,,
1 run on DRs smoked the clutch!!!
Old Nov 15, 2002 | 05:06 PM
  #24
Some clutches have ceramic busts on them which do NOT even require a break in period. My clutch had those busts on them, but I still drove her soft for about 250-300 or so miles.
Old Jul 7, 2003 | 07:00 PM
  #25
1 Hot Z's Avatar
this is the exact same problem I am having, anyone know how to do this drill mod? a write up would be very helpful.
Old Jul 7, 2003 | 09:28 PM
  #26
IrocManiac's Avatar
My question to you guys....did you break them in properly??? I've heard of these types of problems and usually its due to abuse before the clutch is properly broken in.
Old Jul 8, 2003 | 08:08 PM
  #27
1 Hot Z's Avatar
Yes the clutch was broke in properly. I had this problem with my stock clutch and I thought it was a bad clutch so I went with a new spec stage III and I still have this problem. Anyone know how to do the slave cylinder mod?????? How much bigger does the hole need to be and where about do ya drill it?
liamcg97
Nov 25, 2019 05:55 PM
Rod Bender
Jan 1, 2015 03:18 PM
Snoman73
Nov 17, 2014 07:22 PM
Rino1313
Jul 19, 2002 04:31 PM
Rino1313
Jul 18, 2002 05:16 PM
