new Cap and Rotor or sandpaper?
Old Mar 31, 2006 | 02:35 PM
94badrag's Avatar
Hey,
Is a new cap and rotor really necessary or can I gentle clean off the cap and rotor tip with say 400 grit paper and electrical cleaner?
what ya say?
Old Mar 31, 2006 | 06:18 PM
Dan Parker '96's Avatar
Re: new Cap and Rotor or sandpaper?
If you've gone through the trouble of removing the Opti then I'd recommend cap and rotor replacement. The brass contacts (both rotor and cap) do physically erode. A simple clean up may work for awhile but won't last.
Old Mar 31, 2006 | 06:37 PM
blown94's Avatar
Also I believe the contact points are coated originally, so sanding then wil only expose the metals and corrode quicker. Removing any contamination will only be a temporary fix and you'll be back in the same boat id guess in a year or less.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
heus
Sep 8, 2015 12:01 PM
