New cam, pin too short
Old Sep 17, 2008 | 04:39 PM
Green96Z's Avatar
Got my new cam from Lloyd, and the pin is too short. Stock is right around .62 and mine is .5, so it's only a 1/8" difference. The only machine shop out here wants to charge me $70, so I want to see if I might be safe or should I get the pin swapped out? It's not moving by my hands, I already tried.
Old Sep 17, 2008 | 05:53 PM
z28maro's Avatar
bump. ha curious about this myself too. bought a new cam and the pin may be grounded too short. seems in the high .4 range. wonder whats the smallest you could have.
Old Sep 17, 2008 | 06:29 PM
6SpdLT1Z's Avatar
you should be able to do it yourself, do a search. $70 seems high but i'll let you know what my machinest charges me (bought a '93-95 hotcam)
Old Sep 17, 2008 | 06:33 PM
You need to go to another machine shop. $70 to change a dowel pin is robbery.
Old Sep 17, 2008 | 08:01 PM
a4z28's Avatar
At most you should not spend more than 20 dollars, those people are trying to ROB you.
Old Sep 17, 2008 | 08:59 PM
Green96Z's Avatar
Good to know, I thought it sounded high. Is there a particular shop I should look for, like an engine building shop or something? Because I've called every machine shop and only one said they could do it.
Old Sep 18, 2008 | 07:07 AM
NightTrain66's Avatar
I would say $10-20 would be a normal charge.
You might try some "machine shops" with a mill, lathe, press, etc. that does fabrication. A "machinist" should be able to do it in a minute or so. They have pin pullers and can do it quicly and correctly.
An "automotive machine shop" might not wanna mess with it or might try and di it with vise grips or something crazy.
Lloyd
carl.froehlich
Mar 13, 2015 12:38 AM
pimpss96
Feb 12, 2015 01:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Decromin
Aug 18, 2002 10:11 AM
