new cam and heads for 2012
Old Oct 22, 2011 | 03:37 PM
dennis5374's Avatar
Im planning on going with a custom grind 232/240 578/574 110lsa over my current cam which is 230/236 576/571 113lsa. This new cam matched with my le2's and le ported intake should see a decent gain im hoping. Any ideas on how much power ill pick up? I run low 11's consistently and break high 10's occasionally with my current cam and stock milled heads with a 150 shot.I wont be installing the new heads or cam until im done with my forged 358 this winter. Also open too different suggestions for a cam as well. I have a hughes 3000 stall right now but im gonna go with s looser 3600 because my car wil l roll through the brakes at 2000 with my current converter.
Old Oct 22, 2011 | 03:46 PM
Kurt Crosbie's Avatar
What are you running in the bottom end right now?
Sent from my VS910 4G using Tapatalk
Old Oct 22, 2011 | 06:14 PM
dennis5374's Avatar
Re: new cam and heads for 2012
This is for a forged 358 not what im running now. Since you asked I have the stock crank micro polished and turned, stock reconditioned resized "forged" rods, clevite main and rod bearings, hasting rings, speed pro 30 over hypers. I've sprayed it 30+ times with 100-150 shot but I wanna go big so im going with either a howards or scat forged rotating assembly, with j.e forged pistons or diamond forged pistons. May go with an ultra lite set of rods and ultra lite scat crank
Old Oct 22, 2011 | 06:17 PM
dennis5374's Avatar
I may go with le biggest cam with a 108lsa with the new forged motor. Low end loss is not an issue with me because I plan on running a loose converter 3600 stall and with 4.10's the car rarely sees under 2k
Old Oct 22, 2011 | 08:20 PM
dalynchmob's Avatar
Almost same set-up i'm having put on right now. LE2 heads with the 232/240 cam ported intake. My bottom is a 355. I'll know numbers monday.
Old Oct 23, 2011 | 09:06 AM
dennis5374's Avatar
Lol with my stock heads,intake,52mm tb, 576/571 230/236 113lsa, I only made 320 rwhp on a mustang dyno. That's with full bolt ons and PCMforless tune. The dyno 's elevation is 2000 ft higher then where my car is tuned for. The worst part is I went back with a 150 shot and only made 370rwhp but made over 500 ft lb ds. Something seemted fishy too me. I don't think the kid new how to run a eddy current honestly because i've ran a 10.8 and consistent low 11's and a full weight camaro just won't run 10's with only 370rwhp. Track times is what counts in my book
oldschool
Feb 9, 2016 09:21 PM
blac94Z
Feb 18, 2015 11:36 AM
skittlez87
Dec 29, 2014 03:23 PM
Queens94z28
Nov 20, 2014 06:03 PM
