New bottom end? Help parts??
Old Apr 19, 2005 | 04:56 PM
Radd's Avatar
I need a LT1 gurus' wisdom here.
i need a new bottom end for my lt1 motor
355ci block
what all do i need?
options on the motor
5.7 rod
24cc dome
12cc dome
-5 flat top
6.0
-7cc dome
-5cc flat top
6.125
-5cc flat top
6.2
-6cc flat top
-5cc flat top
What should i go with?
i am cluessless on what i need to order. I would like to go with forged internals. run a little higher compression 11:1?
i plan on spraying a 175 shot if that helps.
Joe
Old Apr 19, 2005 | 05:49 PM
Mindgame's Avatar
Re: New bottom end? Help parts??
So ~400rwhp with a 175hp shot?
Cheap
crank: Scat 4340
rods: Scat I-beams w ARP 2000 bolts
pistons: Diamond or SRP with mid-weight taper wall wrist pins from C&A
bearings: King Alecular
oil pump: stock with flow modifications
More expensive
crank: HTC 4340
rods: Scat/Eagle H-beams w ARP 2000 bolts
You don't need to spend alot of money to build something of this caliber. I've done a number of track-only engines with the Cheap components.
-Mindgame
Old Apr 20, 2005 | 06:59 AM
1-bad-z28's Avatar
if you are going NA, stick with flat top pistons. If you are planning on a blower or turbo, go with the dome pistons.
Old Apr 20, 2005 | 07:05 AM
SoloExceptional's Avatar
Dome or dished pistons? I might have things backwards in my head.. Dome = Increased CR Dished = Decreased CR right? Not being funny, just trying to get information straight in my head.
Old Apr 20, 2005 | 08:45 AM
1-bad-z28's Avatar
my bad...i'm stupid. Dished pistons is what i was trying to say. NA=high compression=flat top or domed......FI=low compression=dished pistons. I don't know what i was seeing when i read that but i had it wrong not you.
Old Apr 20, 2005 | 10:21 AM
Radd's Avatar
Cheap
crank: Scat 4340
More expensive
crank: HTC 4340
-Mindgame
what kind of flow modifications?
Killer94z
Jan 13, 2015 12:06 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Hurin
Dec 13, 2014 07:38 PM
