New bolt on times
Old Nov 12, 2005 | 03:52 AM
Kreinmc's Avatar
New bolt on times
Ran a 13.58@104.7 last time out on street tires. This time I took out the back seats and made a dynomax bullet exhaust setup losing a total of about 45lbs. I also ran on ET streets and dumped the clutch at about 5k. I feel like the thing should go atleast 107 with the power it is making, but i guess the car is still kinda heavy.
Best time was...
60' 1.957
330 5.569
1/8 8.514
mph 83.66
1000 11.036
1/4 13.176
mph 105.41
Old Nov 12, 2005 | 07:12 AM
bt96ss's Avatar
Re: New bolt on times
Good job. Those tires made all the difference. You made up a ton in the 60ft time.
Old Nov 12, 2005 | 07:55 AM
Z-RATED94's Avatar
Nice! Looks like 12's are only a tick or two away.
Old Nov 12, 2005 | 08:05 AM
2000GTP's Avatar
Very nice improvments.
Old Nov 12, 2005 | 08:06 AM
chrism400's Avatar
Nice times man. You still have about .2-.25 you could take off of your 60. With 105 mph, and a better 60, that car is a 12 second machine! LCA relo brackets are a must, remove the front sway bar, and put an airbag in the rt rear coil if you haven't already. You are making enough power, it's just a matter of getting it to the ground. BTW, do those Scorpion's fit under the stock valve covers?
Old Nov 12, 2005 | 10:19 AM
fireman's Avatar
Nice times. You dumped the clutch at 5k on ET streets? What clutch do you have? Wish I could do that, I'd leave my axle at the starting line.
I'll be out at Firebird Dec.2nd with my new longtubes, true duals, and clutch. See ya there.
Old Nov 12, 2005 | 02:51 PM
besz28's Avatar
nice times. wish i could get under 2.0 60ft. iam too embarassed to post my times . if i learn how to drive maybe low 12's...heck i need to get into the 12's first.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 18, 2014 12:57 PM
