New best ET & MPH for Lloyd Elliot heads/XE cammed car
Old Mar 14, 2004 | 12:22 PM
Chris 96 WS6's Avatar
Went to the track yesterday:
1.703 60ft
5.038 330'
7.804 1/8th
89.31 mph
12.261 1/4
110.24 MPH
The car runs FLP longtubes, Lloyd's heads with the big valves, and a 224/230 114+4 cam.
Also ran a 12.30 @ 110.30 and a 12.375 @ 108.X when I let the car get too hot in the staging lanes.
Previous best was 12.32@109.5
This is with a Vig 2800 and stock 3.23 gears. 3.73s are on order now and should put me into or very close to 11.90's
Old Mar 14, 2004 | 12:33 PM
Jay-Roll's Avatar
Very nice #'s. Is it me or does your mph seem a little low? Maybe it's just the gears. What else is done to your car besides the headers and stall?
Old Mar 14, 2004 | 12:46 PM
Fastbird93's Avatar
Nice numbers man, glad to see you're finally running right again!!!
Old Mar 14, 2004 | 12:47 PM
1.8ttolt1's Avatar
yeah, i was wondering the same thing about the mph's. is your car really heavy, bad gearing, etcetera? i would think your car would trap around 113-115.
oh yeah, nice 60 ft.
Old Mar 14, 2004 | 01:09 PM
Well like my first post says man its still on the stock 3.23s.
Is it heavy? Never weighed it but its a fully loaded Trans Am so I think yeah its on the heavy side.
Along with the 3.73s I'm installing a TA girdle with bearing studs and also going to put in a solid pinion spacer and weld the axle tubes to the housing...going to try to make the 10 bolt last.
Old Mar 15, 2004 | 01:52 PM
Fenster's Avatar
You need to get that thing to PG and put it on the scales to see exactly how heavy that thing really is. I know that w/ all the options you have that w/ you in the car its everybit of 3700 lbs...
Old Mar 15, 2004 | 02:16 PM
WS Sick's Avatar
I have basicly the same car and with me in it it is 3758 I beleive I'm remembering right.
Old Mar 15, 2004 | 02:23 PM
T/A lt1's Avatar
Yeah you need a little more 60' to get it going better. The 3.73's should really help and a lottle more converter wouldn't hurt either. I would restall that vig to 3200 and take a little weight out like stuff you don't need. You could get into the 11's with your current power level just need some tweaking. Later Clint
Old Mar 15, 2004 | 03:41 PM
Chris'SS #2152's Avatar
What kinda of wheels and tires are you running at the track. With stock ZR1's and BF Goodrich Comp TA's I ran a 12.40@110. Car has no weight reduction at all and stock 3.23 gears also. Good numbers though
Old Mar 15, 2004 | 04:21 PM
26x11.5x16 ET streets.
I'd have another 1-1.5mph if the ET streets weren't so tall in comparison to the 275/40-17s.
Old Mar 15, 2004 | 04:23 PM
chevy94c's Avatar
Nice numbers
Old Mar 15, 2004 | 04:28 PM
Fenster's Avatar
More stall and gears and that car will have no problems seeing 11's IMO. Go w/ the 3500 since you don't drive it everyday anymore.
Old Mar 15, 2004 | 05:14 PM
Loadre's Avatar
Nice numbers chris! I'm hoping to run 12.20s at around 111 mph. Only time will tell.
Old Mar 15, 2004 | 05:19 PM
jkipp84's Avatar
Nice!
Old Mar 15, 2004 | 06:19 PM
LilJayV10's Avatar
Would you expect 113-115mph out of the 224/230 cam? I thought those mph's were more common with the 230/236 cam. ?
