New best ET, help for 12's
Old Sep 22, 2008 | 08:59 AM
LexLT1-Z28's Avatar
Ran a new best Friday nite since I've put on the Kooks headers, 3:73 gears and BFG drag radials.
60' 1.966
330 5.519
1/8 8.499
mph 82.03
1000 11.077
1/4 13.242
mph 104.48
Now I'm itching to get to the 12's. What's the cheapest way to get there. I was still getting some slight wheels spin so I'm not sure a convertor would help that much.
Old Sep 22, 2008 | 10:56 AM
MTBSully's Avatar
i would do some 1.6RR and a good tune.
Old Sep 22, 2008 | 11:03 AM
gatorhead's Avatar
Suspension first! If you can't get it to the ground it ain't worth squat!
Old Sep 22, 2008 | 12:05 PM
slomarao's Avatar
Sfc's, Lca's and a linelock.
Also try to get more weight out of the car. Spare and jack, front sway bar, front bumper support. It will also help out a lot with weight transfer.
Old Sep 22, 2008 | 01:02 PM
LexLT1-Z28's Avatar
Already got subframe connectors, thinking rear drag shocks and a line lock to heat the tires better. How hard to do the 1.6 RR's.
Old Sep 22, 2008 | 01:37 PM
slomarao's Avatar
not that bad. Id say the hardest part is adjusting them.
Cutout maybe? A gear would do it.
Old Sep 22, 2008 | 01:46 PM
95ltslow's Avatar
Some spray would deff get you into 12's
Old Sep 22, 2008 | 02:29 PM
mr.green's Avatar
id do an ewp, airfoil, pulleys,cutout and lose another 75 lbs and you should be there that would be pretty cheap.
Old Sep 23, 2008 | 03:09 AM
redfirehawk101's Avatar
High Stall Torque Converter
Old Sep 23, 2008 | 07:38 AM
87bandit's Avatar
3200 stall and dyno tune
ewp, airfoil, and pulleys are prolly worth like 3-4rwhp combined
Old Sep 23, 2008 | 09:10 AM
slomarao's Avatar
a gear or stall, both would really be great. But either should do it.
Otherwise i would do a ewp and 1.6rr's. The pump and rockers should be worh 16-20rwhp.
Old Sep 23, 2008 | 09:17 AM
Gtpguy's Avatar
My brothers car has a stall, and I don't. After going a round with his car vs my non-stalled car, I am a believer. The best part was he still feathered it out of the hole. If he had DRs, it would have been ugly. Stalls help your 60ft as well.
Old Sep 23, 2008 | 10:59 AM
87bandit's Avatar
I wouldn't recommend 1.6 rockers at this point there are better mods to be had
1.6 rockers = $180-$320
springs = $180-$300
$360 - $620 estimated not including valve stem seals, spring compressor, pushrods (optional),etc
on the high end that's enough for a decent convertor, you'll want to pick up a tranny cooler if you do a convertor, the b&m super cooler is a great unit and can be had for around $60
he already has gears
Old Sep 23, 2008 | 08:22 PM
lt1-xjs's Avatar
Yank SS 3600 and I say 12.8x. Your car runs good. All the bolt-on's should put you 12.6-12.7 WOW!
Old Sep 24, 2008 | 08:48 AM
slomarao's Avatar
you can get lt4 springs for 40 bucks. Rockers are 300 new. So 340 all day.
Or you can find some used for real cheap. 150+40 for springs. 190-200 all day. Not bad in my eyes.
