New belt with AC delete?
Old Apr 25, 2003 | 09:15 PM
96z's Avatar
96z
I deleted my AC when I had my motor was out for my stroker rebuild and now that I tried to reuse the same belt it's too big...considerably... Has this happened to anyone else. What size did you end up using. Is there a way to measure?
Old Apr 25, 2003 | 09:50 PM
95_RipperZ's Avatar
Huh, JPolz, just did that to his car and used the same belt he had. We removed it when we did the cam. I don't think you should need a new belt.
Old Apr 25, 2003 | 10:06 PM
Fuels94TA's Avatar
It should be the same factory belt size. Unless your using a different crank / alt. pulley?
Vinny
Old Apr 25, 2003 | 10:54 PM
If the belt seems too long, try Gatorback p/n 4060635 that you can get at Autozone. The last digits of that part number tell you that the belt is 63-5/10 inches long.
There is another belt used by the f-body that is Gatorback p/n 4060642 that is a little longer (64-2/10"). There were two different a/c pullies used over the years and they were not the same diameter.
The a/c delete pullies are probably all one size, so you could conceivably end up with the wrong size belt depending on what size your original a/c pulley was. This is probably why some people say their original belt was fine and other complain of it no longer fitting.
Measure your belt with a cloth tape if you need to. You can also use a string and then straighten it out to measure it.
Old Apr 25, 2003 | 11:45 PM
NOMAD's Avatar
Cool
Sounds like you don't actually have an AC delete pulley. You will have to have one for things to work correctly with the tensioner. I made my own out of some 1/4" thick aluminum and an idler pulley from a 2.8 GM. Free, you just have to do some measuring and testing
-Shannon
Old Apr 26, 2003 | 03:02 PM
Dr.Mudge's Avatar
I found when I did the swap my stock belt was too loose, was simply told by those who did it to get a new belt - I think the 1LE may have had a 1/4" shorter belt or something, either way the new one worked rather to my supprise.
Old Apr 26, 2003 | 10:13 PM
96z's Avatar
96z
Thanks Shobox,Ill check out those sizes....There are suppossed two different belts b/c when I went to autozone I was asked if my car had AC or not....
Old Mar 27, 2004 | 11:43 PM
rock1501's Avatar
I know its been awhile but did you ever find out?
The reason I am asking is because I just did the !A/C and the belt is too big.I have an underdrive pulley as well.
Old Mar 27, 2004 | 11:56 PM
roadtrip120's Avatar
637 k6
Old Mar 28, 2004 | 12:17 AM
CamaroBoy96Z28's Avatar
Just got my 1LE pulley on. I still need to put my alt. back on and test the belt. Looks like the same belt will work just fine but who knows.
Old Mar 28, 2004 | 12:19 AM
rock1501's Avatar
Originally posted by roadtrip120
637 k6
my old one with the underdrive pulley is a 600k6 I saw they have a 592k6 at the parts store.I hope that is short enough
Old Aug 28, 2006 | 11:23 AM
RE AND CHERYL's Avatar
Re: New belt with AC delete?
Their computer always asks that question. Have you ever seen a 4th gen Camaro without A/C (except the 1LE).
Old Aug 28, 2006 | 11:43 AM
TobyZ28's Avatar
Yup, friends car has no power anything and no AC from the factory. Its definatly not a 1LE either.
Old Aug 28, 2006 | 11:48 AM
lt11997's Avatar
I also had to get a shorter belt when I did my ac!. I don't remember the part number though.
Old Aug 28, 2006 | 08:46 PM
NJ-LE's Avatar
Smile Re: New belt with AC delete?
FWIW: The 95 1-LE factory belt is GM#10236702 and marked 6PK1614EB for a length of 1614 mm (or 63.54 inches) When I replaced mine the closest the store had was the slightly longer 6PK1630 (1630 mm or 64.17 inches). I works fine with the benefit of not having to twist the tensioner so far to remove/install the belt.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
tnmotown
Aug 10, 2015 11:52 PM
