new A4 shifter
Old Mar 11, 2003 | 05:21 PM
5thCamaro's Avatar
new A4 shifter
Does anyone make a shifter for my 95 that allows you to goto 1st manually? It one will shift down to 2nd.
Old Mar 11, 2003 | 05:26 PM
snake_skinner93's Avatar
Take off your shift **** and your shifter panel. You can pull your gear shifter down to 2nd, but will notice there is a small black cube blocking your 1st gear. Heat up a small knife or have something sharp and cut the block off. TA-DA, 1st gear is there! hope this helped ya out.
Old Mar 11, 2003 | 05:27 PM
Kris93/95Z28's Avatar
Thats because you have 2.73 gears. There is a peice of plastic that you have to get rid of. Take off the console piece and dremel the plastic piece that holds the shifter from going all the way back. after that, it will be good to go.
Old Mar 11, 2003 | 05:49 PM
COMNBYU's Avatar
my console lifts up from the back so that you're pushing toward the front (or radio). i didnt take off my shifter. just lift the console up an you'll notice there is a small black plastic cube about .5 square inch in size, blocking the selection for 1st gear. i simply cut it off with a knife. pull console back down and you're set. really shouldnt take more than about 5 min.
jon
Old Mar 11, 2003 | 05:54 PM
tbehling's Avatar
fo what reason did GM blco kfirst gear off from A4 cars with the 2.73's
Old Mar 11, 2003 | 06:06 PM
Silver Z28's Avatar
I don't know about you guys but I have an A4 and 1st gear has always been accessible for me. I have never had to cut anything.
Old Mar 11, 2003 | 06:07 PM
5thCamaro's Avatar
Thanks that little piece of @#$$# is gone now, took a whole two minutes...
Old Mar 11, 2003 | 06:35 PM
It had to do with a drive-by noise requirement with the 2.73 gears when the car was held in first gear. To get around it, they just made 1st gear non-selectable.
Old Mar 11, 2003 | 06:51 PM
mtealz's Avatar
Silver Z28 : You have 3.23s from the factory. So you can access first like all other factory A4 3.23 equiped cars.
Old Mar 11, 2003 | 06:58 PM
Inutero's Avatar
so you can do this? just hope you don't accidently bump the shifter down while your driving.............
So i'm guessing there's a plastic piece blocking the reverse also?
one more thing, what's a good way to get a good start off with an automatic?
Old Mar 11, 2003 | 07:14 PM
mtealz's Avatar
Not for reverse. It just prevents a car with 2.73s from putting the car in first gear. Just cut it off as stated above.
blac94Z
Nov 4, 2015 01:59 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
