New 1LE tranny mount smacking
Old Aug 1, 2004 | 11:03 PM
94zLT1's Avatar
2 months ago i installed a 1LE tranny mount as my stock was cracked bad....now every bump i hit it smacks hard (but it sounds like its more towards the rear? like i have something in the trunk and its smacking every bump)..i went under there today and inspected it and the mount looked fine...i did have to raise the tranny about an inch when i put the screws back in on the crossmember but i felt like it didnt drop that much when i had the jack there? are the 1LE mounts bigger or taller than stock and could that have anything to do with it? What can i do? It sounds and feels bad and i dont even want to drive it.HELP
Old Aug 1, 2004 | 11:24 PM
snorkelface's Avatar
Re: New 1LE tranny mount smacking
Sounds like it's your rear torque arm mount at the differential.
Old Aug 1, 2004 | 11:28 PM
94zLT1's Avatar
how do i inspect it and how do i know if thats it and what would it look like if it was shot?
Old Aug 2, 2004 | 11:16 AM
94zLT1's Avatar
no one else has any suggestions?
Old Aug 2, 2004 | 05:04 PM
Just look at where the torque arm meets the differential. It's actually just bolted to the diff, so if you can wiggle it around, just tighten the bolts.
Old Aug 2, 2004 | 06:05 PM
fesgali's Avatar
I got the 1le and no probs with it. As long as everything is tightly screwed it should be fine. The torque arm is the next thing to look at.
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
mattszm6
Dec 14, 2014 07:09 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
