negative timing on a tech 2
Old Apr 18, 2005 | 04:15 PM
shosty25's Avatar
Just what it says....im showing a negative number for the timing value on a tech 2 anyone else run in this problem????
Old Apr 18, 2005 | 05:22 PM
Re: negative timing on a tech 2
It's not a problem at all . Advanced timing (which is what the timing most always is) is actually a negative number. That's because it is BTDC (before top dead center). If it was + or ATDC, your engine would not even run. Different scanners display it differently, depending on what terminology they use to describe timing.
Old Apr 19, 2005 | 08:36 AM
shosty25's Avatar
Thanks!
oldschool
Feb 9, 2016 09:21 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
squarehead
Jan 15, 2015 07:02 PM
squirrels
Jul 13, 2002 01:58 AM
