Need Windage Tray and the Crank is Keyed
Old Jul 17, 2006 | 08:21 AM
c0rey's Avatar
Hey i need to order a stock windage tray for a stock pan. I looked on the parts stores websites with no luck. Where can I get a stocker nothing special? The new engine I got too was rebuilt from a 93 and it has a keyed crank are the hubs different on the 93s or what?
Old Jul 17, 2006 | 09:46 AM
OBE1 95Z28's Avatar
Re: Need Windage Tray and the Crank is Keyed
My 95 stock crank is keyed; GM just didn't machine a key slot in the crankshaft hub.
Old Jul 17, 2006 | 11:04 AM
c0rey's Avatar
So I just need to take the keyway off the crank then and get a 93 hub. Anyone know where i can get the windage tray at?
Old Jul 17, 2006 | 02:53 PM
OBE1 95Z28's Avatar
No need to remove a "keyway", there's nothing to remove. A Woodruff key (small metal piece) is used to key the crank to the hub if both the crank and hub have a keyway. Again the stock GM parts didn't have keyed crank hubs therefore there isn't a woodruff key installed.
Old Jul 17, 2006 | 03:01 PM
c0rey's Avatar
On this rebuilt engine there is a keyway installed. Thats what threw me off.
Old Jul 17, 2006 | 06:18 PM
1racerdude's Avatar
Ya need to leave the key for the crank timing gear and remove the key for the hub.
Be aware that some had a stepped down key in the timing gear slot.
Your balancer hub should work if it is balanced like a factory engine.
Go to the junk yard and get a baffle.
HectorM52
Jul 30, 2017 11:46 AM
dfarr67
Apr 10, 2015 07:44 PM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
