Need VATS help ASAP! Have to work tomorrow!
Old Jul 14, 2004 | 11:53 PM
madhatter's Avatar
Ok so my security light keeps flashing when I try to start my car. So I figure its the VATS. When I measure my key with an ohmmeter with the setting at 200k, it comes up 11.80. Which resistors do I need? I really need help as soon as possible, I have to work tomorrow afternoon. Any help would be appreciated!
Old Jul 15, 2004 | 08:05 AM
Not quite sure about your meter scale, but sounds like you were in a k-ohms one. Your 11.80 reading would be 11,800 ohms. That is right on for pellet #15 . Get a resistor or combination of them to add up to anything in the high-low range for #15 and you should be good to go.
Old Jul 15, 2004 | 11:02 AM
madhatter's Avatar
OK, looking at the chart, do I splice into both wires,or just one of the wires? Also, which resistors do I get? They have a bunch of them,some 1/2 watt, some 1 watt, etc.
Old Jul 15, 2004 | 11:12 AM
Either ½ or 1 watt should work. You connect one wire to one side of the resistor and the other wire to the other side of the resistor. It does not matter which goes where, as there is no polarity issue with a resistor.
VATS connector
Old Jul 15, 2004 | 12:39 PM
madhatter's Avatar
Thanks man! Once again you got me out of a jam. What would cause it to stop working? What needs to be replaced? Once again, THANKS!
Well, off to work!
Sean
Old Jul 15, 2004 | 12:47 PM
If putting in the resistor bypass makes it work, the key cylinder, it's wiring or even the key could be at fault.
Old Jul 15, 2004 | 01:20 PM
crAzy95z28's Avatar
well if ya need a new one...i have the VATS, key chip, and key cylinder for sale....just pm me if needed...
randy
from a 95 Lt1
eazyZ
Mar 1, 2015 07:12 AM
Lakebratt
Feb 5, 2015 07:55 PM
Brake_L8
Jan 20, 2015 09:44 AM
ChrisFrez
Jan 11, 2015 03:47 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
