Need a for sure way to tell if opti is dead
Old Dec 9, 2004 | 08:31 PM
pHEnomIC's Avatar
I got my car pretty much apart because my water pump was leaking and i was replacing it. I think my opti is dead because i was having misfire problems lately and sucky gas mileage 13mpg on premium and just about everything else is changed. It would make sense that the coolant leaked onto the opti.
I do have a burnt wire which i changed and had a loose spark plug which i will tighten tomorrow. How do i tell if the opti is good of bad?
Old Dec 9, 2004 | 09:46 PM
Robs97Z28's Avatar
Re: Need a for sure way to tell if opti is dead
one way would be to see if you have spark coming from the coil wire.
see if this heres also: http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Dec 9, 2004 | 10:43 PM
Bersaglieri's Avatar
The way I figured out was replacing mine.
-Dustin-
Old Dec 9, 2004 | 11:18 PM
1racerdude's Avatar
Grab the coil wire and spin it over,if you don't feel anything it's dead.On the other hand if it ain't dead you will be picking yourself up off of the ground.
Thats a real sure way to test it and you asked for a sure way.
Otherwise hold the coil wire about 3/8" from any grounded metal and it should jump with a bright blue color, no orange. That does not mean that the fire is getting to all 8 cyls.The cap and rotor may be TU.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
