Need Some suggestipns..ASAP
Old Jan 31, 2003 | 03:48 AM
94 TA TT2S's Avatar
Angry Need Some suggestipns..ASAP
Ok here is the deal....last week I replaced my opti and installed a meziere w/p, while I had the opti out I figured I would change the seal while I was there, I replaced the seal and reinstalled the opti (which I am assuming it can only go one way...being a 94) water pump, everything went good...Till I started the car and notice the wp o-ring was leaking so I had to remove and replace it...Well I got that taken car of ..the car started and run great till from somewhere not quite sure , I notice a leak its an oil/ ??? leak... it is light brown milky looking...where could this be coming from????
I am not sure if this is connected in any way but I went to start the car the other day and it backfired and a big cloud of white smoke came from my air filter..any suggestions on what could cause this would be greatly appreciated..
Now with that said there is one other problem ...I had the car running for a couple of days after that....run smooth..But still has the leak ..Now 2 days later the car will not start...I am getting fire all the way to the plugs...I can turn it over time and again but will not start....I have noticed a strong smell of gas after I try to turn it over but it still will not start....
Please help....any help with any of these problems would be great......Thanks...
