Need some suggestions!
Old Oct 24, 2003 | 10:35 AM
LeeS's Avatar
Question Need some suggestions!
What causes my car to be hard to start. I have to crank the car for like 2 or 3 times before it will start.
I have Replaced: OptiSpark, Plugs & Wires, New EGR Valve, IAT Sensor, Cleaned Throttle body, Cleaned PVC Valve.
I have 76K miles on my 1997Z28!
It didn't used to take it long to start.
I need your guys help!
Thanks Lee!
Old Oct 24, 2003 | 11:02 AM
BUBBA's Avatar
Well, if your fuel pressure is ok, then you might check your coil.JMHO.
Did you replace these things before or because of the hard starting?
If before, then you need to make sure that all the items that you changed were done correctly.
E.g., are your plugs gapped correctly? They should be .050 NA. Oftimes the plugs don't come with the correct gap. Just a thought.
Old Oct 24, 2003 | 01:09 PM
LeeS's Avatar
anybody else want to comment !
Thanks Lee!
Old Oct 24, 2003 | 01:14 PM
S.J.S.'s Avatar
Before I even read the replies that was exactly what I ws thinking. If you are sure you gapped them right, I would go straight to the coil. Then go from there.
Old Oct 27, 2003 | 02:22 PM
LeeS's Avatar
Hi Guys!
I let my local Chevy dealer where I used to work change the plugs & Wires and the OptiSpark for me.
Do you think I should still check them. Thanks Lee!
Old Oct 27, 2003 | 02:35 PM
lt195ta's Avatar
you should still check them...seems to be a valid argument
Old Oct 27, 2003 | 02:49 PM
thermwood1's Avatar
Start with the basics.
Check for spark at the coil and the plugs.
Check fuel pressure.
Check battery voltage, with no load and while cranking.
You can't just expect an answer, have to do a little work.
Old Oct 27, 2003 | 03:12 PM
Fastbird93's Avatar
A lot of the long cranking issues I've seen is a failing fuel pump check ball. Basically, the pressure is bleeding off, so you have to build that fuel pressure back up before it will fire off.
Old Oct 27, 2003 | 04:10 PM
kudah440's Avatar
Have you gotten this figured out yet, and does it smell like its flooding? Im positive that I cant help, but this item may be able to help somebody else figure it out, in theory if you figure yours out mine will be also, since mine is acting the same...only worse.
Old Oct 27, 2003 | 05:55 PM
LeeS's Avatar
I promise I'll let you guys know soon as I get a chance to look at it. I will tell you what I find.
Thanks Lee!
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
