Need some opinions and motor noise
Old Dec 30, 2005 | 11:04 AM
96blkform's Avatar
Well, towards the end of this past summer, I noticed that I had a noise coming from under the hood on deceleration. I had a look and heard what seems to sound like something loose from the drivers side head. It does not make a noise when idling nor when you rev it up, only when it revs down. I have wondered if it was a collapsed lifter, I have the Comp R's. I checked the oil and no shavings or metal peices. I am not sure on what it could be, the rockers are adjusted fine and as I say the comp R's have been fine (done close to 7000 miles on them with no problems). I have been told it could be a sticky valve? Not overly sure, but is there something I can through the motor to see if it cures the problem. My heads swap was done only 2500 miles back. Would seafoam be an option or like I say is there a something else I can use.
Thanks guys
Fatdog2
Feb 12, 2015 12:24 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
squarehead
Nov 21, 2014 08:02 PM
Omega9
Aug 2, 2002 12:33 AM
