need some info on guideplates
Old Sep 3, 2006 | 10:53 PM
95LT1conv's Avatar
im gonna be installing a set of 1.6 nsa rr soon and want to know what guideplates you guys suggest. I know that comp, crane and summit make thier own, but read alot about only using the GM performance ones.
Old Sep 3, 2006 | 11:11 PM
LenT1's Avatar
Re: need some info on guideplates
I don't have any experience in this area but I have seen most people recommend using the GM ones.
Old Sep 3, 2006 | 11:19 PM
GMPP or adjustable plates.
Old Sep 3, 2006 | 11:21 PM
HardcoreRM125's Avatar
GM's or the Isky Adjustables ... Those are your only real options.
Regular SBC ones wont work right.
Old Sep 4, 2006 | 08:25 AM
96capricemgr's Avatar
I tried Comps and while it would run like that the alignment I was not happy with. Swapped to the GMPP ones and alignment is much better but still not perfect. Most of us will be happy enough with the GMPP. The more **** among us will want the Iskys.
While on the subject is this a valvespacing change ir is it inconsistency???? If it is just a different measurement then I would think we could get someone to make some plates just the right width. If it is inconsistency that is the source of the problem well we are stuck with the good enough GMPP or the adjustables.
Old Sep 4, 2006 | 11:26 AM
95LT1conv's Avatar
im gonna be changing to lt4 springs and 1.6 nsa rr
blac94Z
Nov 4, 2015 01:59 PM
colts0455
Oct 4, 2015 09:47 PM
drt
Sep 27, 2015 04:39 PM
frankrizz
Sep 23, 2015 04:21 PM
CARiD
Sep 7, 2015 08:21 AM
