Need some help, SES Light, no cooling fans on at all
Old Aug 20, 2005 | 03:16 PM
LT1Firehawk's Avatar
Today I was driving, and I got a SES light, got home and noticed when my key is in the "on" position my cooling fans no longer come on, nor do they come on at all, even with the AC on. What do you think it could be, I cant get it scanned today, and its a 94 so autozone cant scan it. Any help would be appreciated, its like 98 outside and there is no way in gonna drive without fans.....I also noticed my thermostat needle going crazy, it would pin down at 160 when the car was warm, then pop back up, and sometimes fluxuate???
I also noticed some missing in the upper rpms, but I attribute that to the engine running hot, my car sometimes misses when its hot.
Old Aug 20, 2005 | 04:05 PM
white/blackss's Avatar
Re: Need some help, SES Light, no cooling fans on at all
sounds to me like you may have some air in your cooling system. atleast thats what was wrong with my car when the temp guage was doing that.
also might explain why the fans arnt running.
did you check the fuses under the hood?
check all the fuses and after it cools down with the car off check the coolant level.
Old Aug 20, 2005 | 05:01 PM
Maybe the SES is for the fan circuitry. Get it scanned.
Old Aug 21, 2005 | 08:23 AM
slopokrodrigez's Avatar
Take a look near the battery side of the radiator below the coolant level sensor. The fans are grounded there and several folks have had a problem with that ground point. Also try pulling out and reseating the fan relays in the underhood electrical panel.
Old Aug 21, 2005 | 04:13 PM
Jps 1LE's Avatar
Yeah get it scanned for the code. Also when my SES light was on and my fans didn't work it was b/c of a blown fuse. There was a ground out at the O2 harness which constantly blew my fan fuses. From what i read it is pretty common. Check fuses and see if there is a possible ground out. Good luck
MattFick
Feb 15, 2015 10:16 PM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
