Need some help Emissions related
Old Jul 20, 2004 | 08:15 AM
Got-LT1's Avatar
My brother's 94 Z28 just failed emissions. He failed HC (needs 117 got 2000) and NOX (forgot the numbers) any idea what causes those numbers to be so high? The car has shorty headers, a cc304 (not sure if it is tuned or stock tune how can you tell on a 94?) and the usual bolt-ons to back those up (cai, etc). I believe that the AIR system is gone and the EGR might not be working, but could that cause such high numbers?
My dad said he saw an unpluged senser on the drivers side, that was just hanging near the fuel lines and looks like it needs to connect to the engine block, I have yet to see it, any idea what that could be?
Thanks for the help.
Old Jul 20, 2004 | 09:51 AM
HBHRacing's Avatar
Re: Need some help Emissions related
between everything you ahve said... yeah that will do it.. if the cam is not tuned ocrrectly and it;s running rich tat will do lot of it. AIR system doesn;t mater that much as long as you get teh car hot first. EGR should be working correctly if you wnat it to help. things that are especialy important are the way the motor runs and the 02 sensors. they say a califorina test showed that over 70% of teh cars that failed a test was due to 02's..
Old Jul 20, 2004 | 10:19 AM
Got-LT1's Avatar
Yeah I was going to replace the O2s for him when I get back home just to make sure it wasn't them. Anything else?
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 10:09 AM
SergheiS
Sep 29, 2015 08:56 PM
damnyankee36
Sep 9, 2015 07:06 PM
