Need some help....
Old Jul 29, 2007 | 10:16 PM
bowtiekid's Avatar
Need some help....
Ok I dont know of anything else to check...
This is the list of NEW parts
-Opti
-MAF
-MAP
-EVAP SLND
-Changed the burn plug wires
- O2s
-New module underneath coil pack (delteq)
-sanded all the grounds
-New wiring harness for the engine (only wire that still shows bare copper and frayed is the oil level sensor)
-Checked plugs
-Checked wires
It misses terribly
then it throws a code then runs really boggy....I really need help
I cannot figure this out....
Old Jul 29, 2007 | 10:18 PM
dangalla's Avatar
i would hope before you did all of that you did a compression test
and what is the code it throws
Old Jul 29, 2007 | 11:52 PM
bowtiekid's Avatar
its not mechanical...
the car runs beautiflly when the code isnt on...
and Idk its a 95
I just have no clue...
Old Jul 31, 2007 | 01:20 AM
bowtiekid's Avatar
ttt
I know someone has ideas as to what it could be
Old Jul 31, 2007 | 07:24 AM
95LT1conv's Avatar
no way to help w/out the code. get it scanned and come back with what code it is throwing
Old Jul 31, 2007 | 01:26 PM
bowtiekid's Avatar
Ok I got the code pulled today...its a 95...ya...
the code is 42...
thats the only code..
Electronic spark timing
Old Jul 31, 2007 | 01:33 PM
sabre81's Avatar
Try a new ICM.
Old Jul 31, 2007 | 01:38 PM
bowtiekid's Avatar
Using delteq.....
Old Jul 31, 2007 | 01:58 PM
sabre81's Avatar
i think i left my attention to detail at home today.
Old Jul 31, 2007 | 02:02 PM
96ZCamaro's Avatar
Sounds like a crankshaft position sensor.
Old Jul 31, 2007 | 02:04 PM
sabre81's Avatar
Theres no crank position sensor in a 95 is there?
Old Jul 31, 2007 | 02:05 PM
96ZCamaro's Avatar
Idk, my car is a 96 and it has a sensor from the timeing cover down by the crankshaft. I guess I havent looked too hard at a 95 to really tell.
Old Jul 31, 2007 | 02:11 PM
94 NO TOP Z's Avatar
95= no crank sensor but, the crank sensor on 96-97 does nothing as far engine control. It is just there more mis-fire detection.
Old Jul 31, 2007 | 02:18 PM
sabre81's Avatar
Maybe PCM is screwed? orrrrr.. maybe a one of your coils is defective? Only two things i can think of that are left.
Old Aug 1, 2007 | 04:14 AM
bowtiekid's Avatar
yea the pcm is fried....
4 pcm that has been in my car...
my car likes to eat pcms alot
wildracer
Jul 30, 2010 12:49 PM
ttop1997
Jun 18, 2010 11:27 AM
AlwaysCode390
Oct 30, 2009 05:28 AM
sick9lt1
Aug 25, 2009 01:55 PM
1994TransAm
May 29, 2007 08:14 PM
